Simulating Arduino's Serial Monitor with Labview?
Accepted by topic author hrh1818
You have to continuously add to the string with a shift register and concatenate string function as I said. You also have to set the scroll bar position with a property node.
Message 11 of 12
(1,638 Views)
Hello Dennis,
My apologies I didn't understand your objective when you said " Use a shift register with a concatenate string function. Take care to limit the max length of the string. Use a property node to set the string position to the end of the string.".  Now it makes sense.
Thank you for your help
Howard
Message 12 of 12
(1,629 Views)
