Simulate the Hysteresis Loop in Labview
I wanted to simultate hysteresis curve with defined co-ordinates. I tryied by simply using two sine waves with delay and using hyperbolic trignometeric functions. But in this I coudnt shift the curve by defined co-ordinates. I want the same plot to be in between 15-35 on x-axis and -5 to 45 on y-axis. Anyone please suggest. Posting the code.
(6,039 Views)
Accepted by topic author Sanky
Not sure what you exactly mean with 'defined coordinates'..
If you want to re-scale your XY graph to different X and Y axis ranges, just apply gain (multiplication) and offset (addition) to your X and Y arrays.
(6,006 Views)
Hi Sanky,
use simple math you should have learned in elementary school:
(6,001 Views)
