If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
02-03-2017 12:09 AM
I wanted to simultate hysteresis curve with defined co-ordinates. I tryied by simply using two sine waves with delay and using hyperbolic trignometeric functions. But in this I coudnt shift the curve by defined co-ordinates. I want the same plot to be in between 15-35 on x-axis and -5 to 45 on y-axis. Anyone please suggest. Posting the code.
02-03-2017 01:53 AM
Not sure what you exactly mean with 'defined coordinates'..
If you want to re-scale your XY graph to different X and Y axis ranges, just apply gain (multiplication) and offset (addition) to your X and Y arrays.
02-03-2017 02:45 AM
