Simulate Keystrokes for an executable run by System Exec.vi ?
I have an executable that I call using System Exec.vi. The executable opens when I use system exec, but it needs CTRL + S to run. So I want to simulate that keystroke. Also, once it completes, I want to simulate keystrokes to close. In short, I do not want the user to do anything other than run the VI which has system exec.vi. Everything else is done by simulating keystrokes which in turn depend on some conditions I would generate. Thanks.
Kudos are the best way to say thanks 🙂
(4,241 Views)
The attached vi shows how to simulate keystrokes. Send the Control Key down code, S key down code, S key up code, then control key up code.
- tbob
Inventor of the WORM Global
(4,241 Views)
Hi
I have LabVIEW 7.0 and looks like your VI is from 7.1 and doesn't open in mine.
(4,241 Views)
This happens all the time. Please mention what LV version you are using in your original question. Here is the 7.0 version.
- tbob
(4,241 Views)
