Simple xyz coordonate plot of points with specific color and shape, need help!
I'm missing something in the way Labview makes a 3D plot.
I have a excel sheet with 5 columns: x,y,x,color, shape (i.e. square, circular, etc..). Each line is a new point. What I want is just to position these points with the right color and shape, no surface or line between point. Origin should at (0,0,0).
Olivier
"Dummy umanum est, perseverare diabolicum."
Message 1 of 9
(4,337 Views)
here is my VI and a data file.
Colunm 1-3 are x,y,z
Colunm 4 is the point
Colunm 5 is the color
For some reasons, I get only the last point drawed. Where is my mistake?
Thanks olivier
Message 2 of 9
(4,319 Views)
You have the 3D Curve VI inside the loop. Since you are autoindexing the values (x,y,z), it's only plotting one point at a time. I don't understand how one is supposed to intepret different values for the color and shape columns since you have only one plot, and point style and colors apply to the plot, not to individual points.
Message 3 of 9
(4,315 Views)
I think I wasn't clear. I'm looking to apply a specific shape/color to individual point. Thant's what I cannot figure out.
Olivier
Message 4 of 9
(4,299 Views)
I do not think the 3D graphs support a different shape for each point, and for tht matter the shape of the points.
I used a 3D picture to do this.
That illustaes it is possible to dicate the XYZ and color.
Othre shapes are possible but they did not fit with the specs of that project. I did experiment with "skinning" the sphers and that worked as well.
So I suggest trying the 3D picture and skip the 3D graphs.
Ben
Message 5 of 9
(4,297 Views)
BTW:
Using the terms "simple" and "3D" in the same sentance propbably breaks one of the laws of thermodynamics.
Ben
Message 6 of 9
(4,294 Views)
Could you post some sample code for that...please!
Olivier
Message 7 of 9
(4,292 Views)
Olivier
Sorry no can do! (I would be promptly fired for giving away code to anyone other than a current customer and I would like to avoid that for the time being.)
LV ships with 3D picture examples including a Solar System demo which is where I started when developing what I posted above.
Standrad shapes are also included. If you want to get exotic you could even crate your own shapes.
Still trying to help (without getting fired),
Ben
Message 8 of 9
(4,288 Views)
I understand. Thanks for the tip.
It seems to me something really basic that should be added. I'll try to submit it.
Olivier
Message 9 of 9
(4,283 Views)
