Simple X Control
Cluster containing:
1. Radio button with 2 selectors
2. Two (2) numeric controls
Radio selection 1 -> Numeric control 1 enabled, Numeric control 2 disabled and grayed.
Radio selection 2 -> Numeric control 2 enabled, Numeric control 1 disabled and grayed.
Is there a way of building a control (i.e. xcontrol) with this simple inbuilt functionality?  Do not want to code properties in subVI of main VI.
Thanks.
(6,954 Views)
Yes, and your Xcontrol is rather simple.
Sorry, cant draft a code right now...
________________________________________________________________________
"When I need the side of a building to view all the code..." -Mark Yedinak
"...when you need a navigation window to view the navigation window..." -Jeff Bohrer
(6,947 Views)
I'm after example code so I can start learning how to use xcontrols.
Thanks.
(6,930 Views)
In LabVIEW, go to Help->Find Examples... and perform a search for XControls.
(6,928 Views)
What you are hoping to do is definitely possible. I found an example for you that walks through how to create an XControl.
(6,904 Views)
I'm sharing some XControls on GitHub, feel free to use. https://github.com/AntoineChalons/XControls
And here's a place we can discuss about my examples if you are interested : http://lavag.org/topic/14432-iphone-like-password-string-xcontrol/
Epictetus
Antoine Chalons
(6,899 Views)
I wrote a quick Simple Xcontrol with the function that you asked. Try NI examples and write some.
Anand kumar SP
Senior Project Engineer
Soliton Technologies Pvt Ltd
(6,876 Views)
