Simple Output File Formatting Question
First off I will prefix this by saying that I am not a very good LabVIEW user.  Everything I have learned I just taught myself from looking at instrument control vi's.  Well I am trying to take a number of readings from my Agilient switch 34972A.  I can send the command, convert the return string, and make the reading into an array.  The issue I have is when I try to write that array to a file.  If I take the array directly as It comes out of the for loop that converts it from a string to an array, I end up with a file that looks something like this:
TimeData
025.8
124.3
226.1
323.9
025.7
124.4
225.9
324.1
And so on.  This is not at all what I want.  I understand what is happening but don't really know how to fix it except that way I did in my program below, but this is very tedious especially if I want to expand to 15 or 20 channels.  In this method I break the array appart recombine it and then write it to file and I end up with a file like:
TimeData0Data1Data2Data3
0.2525.824.326.123.9
0.525.724.425.924.1
And so on.  My question is that I am sure there is a simpler way to do exactly this but I can not seem to figure it out.  Any suggestions would be great thank you.
(2,685 Views)
Accepted by topic author kgould
Out of curiousity, what's wrong with just saving the instrument's response straight into at text file?  Seeing that it is comma delimited, I would save the data to a *.csv (command separated values file).  Then Excel will even read it nicely.
Something like this is what I'm envisioning.
(2,681 Views)
