Simple Event Timing on/off (lights, pumps, ect)
I can take a look at it, but the computer I am at for the rest of the week only has 6.i on it. Therefore, you will have to save it down for version 6.0. Then I can take a look at it.
-Evan
Message 11 of 13
(534 Views)
thanks here it is
Mitchel Kuijper
Message 12 of 13
(534 Views)
Mitchel,
attached is the library for the new vi..
I had to remove the while loop inside of the subVI and put it in the caller VI.
The problem you are seeing is that when a program runs a subVI, it passes data in, the subVI runs it's routine, then when it completes, it outputs the final values.
You can do this the way i have in my example, or you could use global variables. I'm sure there are other ways to do it as well.
This isn't a normal subVI, and has to be treated a little differently.
Message 13 of 13
(534 Views)
