Simple Event Timing on/off (lights, pumps, ect)
I want to make a simple vi to turn on and off lights for my aquarium at a selected time of day everyday.
The vi I should have a time and date stamp with a control for selecting the on and off time.
Sound�s simple enough but I�m having difficulty making any of the vi�s I�ve found work.
Does anybody have a vi that works well and is simple
Your help is appreciated
Mitchel
Message 1 of 13
(4,012 Views)
Find attached a sample vi to get you started.
Message 2 of 13
(4,012 Views)
there seems to be part of this vi that is missing.
"timed while loop.vi" is a vi that i don't have.
i'd like to have a look at your sugestion
thanks for your help
Message 3 of 13
(4,012 Views)
Here is the complete vi
Message 4 of 13
(4,012 Views)
If I understand what you are doing, this can be done using the get date/time function, and entering the on time and off time as a string. You break the string into hour, minute, and second. Then compare the current time to the ON/OFF times to control a boolean indicator. Then you would have to pass out the boolean value to control a switch for a light.
Attached is a working VI that does everything but the actual IO to control the light. Just think of the boolean indicator as being your aquarium light.
Message 5 of 13
(4,012 Views)
Evan thanks a lot for your help.
The Vi you sent is nearly exactly what I�m looking for!!!!
I don�t want to look a gift horse in the mouth but there are a couple of things id like to change.
Do you know how to make the �enter time of day on/off� a control with up and down arrows to change the minutes in 15min increments. I was hoping to use a 12hr am/pm clock as well.
I was playing with a the vi but was unable to get a digital control to do what I wanted.
I also want to make this vi a subvi to use for multiple timing events.
I am able to understand most of this vi except for the pattern match and decimal string to number functions you used. The light in my head just isn�t coming on. I see that it works I just don�t understand how yet.
I�m looking at the help file to get a better understanding.
Also I�m not sure if the LED in your vi is big enough so I made it a little larger (for the blind) (kidding)
Thanks again for your help
Mitchel
Message 6 of 13
(4,012 Views)
Mitchel,
give this a try. Let me know if you need any explaination for this. This version seems pretty self explainatory.
Message 7 of 13
(4,012 Views)
Well thanks so much!!
This is a very simple vi that I�m able to understand completely.
I have only taken basics 1 and 2, two weeks ago so all this is very new to me.
I�m also new to programming but have a back ground in electronics.
I�ve spent a lot of time looking for a simple vi to do this type of simple timing. Much of what I�ve looked at is too difficult for me to follow and likely over kill for my needs.
Looking at other peoples code is a really good what to see just how things are done.
Mitchel
Message 8 of 13
(4,012 Views)
Looking at other peoples code is a really good way to see just how things are done.
Mitchel
Message 9 of 13
(4,012 Views)
Hello Evan just wondering if you could tell me why this vi might not be working?
I have edited your vi a bit and used it as a sub vi but it doesn�t seem to be working.
thanks
Mitchel
Message 10 of 13
(4,012 Views)
