‎05-11-2012 04:36 PM
Hello, I am very new here. Want to create a very simple program. Press a button-> start a 20 s Timer-> turn on a LED. Can anyone tell me , how to do that ?
Thanks in advance .
~Repon
‎05-11-2012 07:15 PM
Repon,
That is a very simple program. Have you tried anything? What worked or did not work with what you tried? Have you had any training or have you worked through tthe Getting Started with LabVIEW tutorials on line?
Lynn
‎05-11-2012 08:38 PM
‎05-12-2012 11:09 AM
My Question is , which timer function should i use for this purpose ?
~Repon
‎05-12-2012 11:21 AM
Did you read the post completely? I gave "ELASPED TIMER" function as suggestion. This will let you to do other task inbetween 20s and at the end it will give boolean high. WAIT ms is there but you will not be able to access the Frontt panel for 20s than.
