06-30-2015 02:20 PM
Quick bug report.
When dropping a Path Control on a FP, the browse button is shown by default.
If you hide it AND THEN right-click on the control >>Properties >> Appearance >> and check off the Show browse button:
the result is identical to what you would have obtained by right-clicking >>Visible >> Browse button (or doing nothing to the control to begin with).
Except for the Silvers style path control, where the browse button ends up hidden behind the control:
To clarify: with the Silver Path Control, showing/hiding the Browse button via the RCM >> Visible Items >> Browse button works. Doing it through the RCM >> Properties >> Appearance >> Show browse button is glitchy.
Tested on LV 2013 SP1 64 bit
07-01-2015 02:57 PM
Hi X,
Thanks for submitting this! I was able to replicate the odd behaviour in LabVIEW 2013 SP1. However, I did not see it on the version of LabVIEW I have installed - 2014 SP1 32 bit. I looked around a bit, and it appears this was submitted and fixed as a Corrective Action Request (CAR) for LabVIEW 2014. I installed LabVIEW 2014 64-bit, and the behavior was not present.
Again, thanks for bringing this up - it took a focused eye to catch it.
