Signalwaveform offset Problem
Hi all,
I've a problem during the  geneartion of a signal wave(Sine,Square) on FPGA (PXIe-7868R).
I'm able to generate a signal with the right frequency and amplitude but when I change the Offset (1V to 5V) the signal remains the same and does not change and when i put a high value  the signal is distorted
Any suggestion?
(1,518 Views)
When you introduce a DC offset to a signal, it does just that - it offsets the signal by that amount.  Let's say you have a signal that varies from +5 Volts to -5 Volts.  With an offset of zero Volts, you will have a signal that varies from +5 Volts to -5 Volts.  Introduce an offset of +5V and now your signal varies from +10 Volts to zero Volts.
I'm pretty sure the reason you are getting distortion is because, by offsetting the signal by +5 Volts, whatever is producing the signal can't go that high - it is clipping on the high side.  It's generally not a good idea to run a source in this fashion.
Bill
CLD
(Mid-Level minion.)
(1,471 Views)
Thanks for your reply
I agree with you. the signal distroy when I put a big value in the Offset for exemple 15.
my problem when i put a value betwin (0 to 10) the signal does not change that what Im trying to figure out
(1,456 Views)
