DAQ Traditional problem with WIN7 and Labview 6.1
Hello! I have a program LabView 6.1 that work perfectly with Win NT and makes uso of traditional DAQ with NI-PCI-6711. I have switch to Win 7, but the program stops when the analog output funtion enters with Error 10401 " occured at AO group config. The Board NI6711 is not seen by MAX2.2, but is seen by MAX20 correctly. I tried to load last traditional DAQ driver :7.5, but it is not compatibility with Win 7. ( I will try to load version 7.4 which is compatible with win 7)  I ask help to community without changing LABview version . Thanks
(987 Views)
have a look at this:
https://www.ni.com/content/ni/locales/de-de/support/documentation/compatibility/17/traditional-ni-da...
The last Trad-DAQ driver that is compatible with LabVIEW 6.1 is version 7.4, so you definitely have to switch to an older version than 7.5
While those versions officially do not support Win7 there is a good chance that it will work. But you are on your own if something does not work.
Regards, Jens
Kudos are welcome...
(979 Views)
Thanks, I'll try
Thanks, I'll try
(938 Views)
