Signal generation from number of harmonics
Hi ptavernise,
you don't need any shift register at all according to your task description!
Come è il tempo nel nord Italia? Io vado in vacanza ... 😄
Message 11 of 50
(2,276 Views)
A long time ago (before LabVIEW was invented), we were using what we called a "Sum of Sines" stimulus to deliver a pseudo-random (slow) waveform with a period of about 5 minutes that was composed of relatively-prime (and all odd) harmonics, like 7, 19, 39, ... .  This was "unpredictable", but could also be on-line averaged at the various harmonic frequencies.  We managed to do this without LabVIEW, without MatLab, indeed using "machine-language programming", so you should be able to do this (relatively simple) task yourself, even if you take a step backward, abandoning the rather more sophisticated and "programmer-friendly" tools that LabVIEW provides, and, instead, think of how you would do this with a pencil, paper, a calculator, and a table of the sine function.
Message 12 of 50
(2,271 Views)
Mi sa che la vacanza la dovrai rimandare perchè piove a firenze. Come posso fare dunque non ho capito.
Message 13 of 50
(2,264 Views)
Hi ptavernise,
simple autoindexing:
Spoiler
Immagino che sia presto in Ravenna ...
Message 14 of 50
(2,254 Views)
instead if i'd like to see the sum of i-th harmonics where i stands for the number of harmonics, which can be changed by front panel?
How can i do?
Message 15 of 50
(2,227 Views)
when you want to display a sum you need to add up the waveforms in the loop. Use a shift register...
Message 16 of 50
(2,231 Views)
Precisely, i'd like to see on the output waveform the signal of amplitude plotted in this picture.How can i modify the VI?
Message 18 of 50
(2,213 Views)
Please i need your help!!!Answer me!!!
Message 19 of 50
(2,195 Views)
Could someone help me?
Message 20 of 50
(2,182 Views)
