Signal delayed when using multiple VISA connections
For a project, I'm using 2 digital pressure sensors (Omega PXM409) to measure the pressure at 2 different locations. However, I noticed that one of the signals suffers a serious delay. This is seen when I blow into them at the same time (and yes, they can handle that pressure difference), and I see one of them giving a peak immediately, and the other some time later. In the mean time, new values are obtained and shown for both sensors. The delay increases when my programis running for a longer time; in the beginning it is something like 0.5 s, later it can become 5 s or even worse. It is not the sensor itself, as one time sensor 1 is delayed and sensor 2 isn't, while a next time I run the program it is the other way around. Also, when I use only one sensor, it works fine, no matter which one I choose. I've also noticed that, when adding a third sensor, the problem appears for 2 of them (so, only 1 sensor seems to give the signal immediately and 2 sensors are delayed). Any ideas what is causing the problem, and how I can solve it?
Thanks in advance!
Message 1 of 9
(4,292 Views)
Hi RHJH,
handle each sensor in its own loop. Then test again…
Message 2 of 9
(4,285 Views)
Thank you for your reply. I did test that already (should have noticed that, sorry), but it didn't work.
Message 3 of 9
(4,281 Views)
Hi RHJH,
what happens when you switch the COM port for these two sensors?
Does the problem switch too (so it is related to the sensor) or does it stay with the COM port?
Still I would use separate loops for each sensor/COM port…
Message 4 of 9
(4,265 Views)
The problem switches too in that case, so it does not stay with the COM port.
edit: re-reading your post, I may be unclear in what I mean with switching. I switched them in the i/o block (so in labview), and then the other sensor gets the problem. So the same sensor on the same COM port, but at a different location in the VI, works fine then. However, when restarting Labview, the problem may occur the other way around (so that the other i/o block gives fast response).
Message 5 of 9
(4,262 Views)
Accepted by RHJH
If those VIs are not set to be reentrant, that could potentially cause some issues.
Message 6 of 9
(4,257 Views)
How can I see if they are reentrant, or how can I change it?
Am I correct when I state that it may introduce delays between the signals (so the samples of the 2 different sensors will never be obtained at the same time, and the theoretical sampling rate cannot be reached), but that this should not cause a delay in an external signal being transfered to Labview?
Message 7 of 9
(4,253 Views)
Found the reentrancy thing, and it seems to work! Thank you very much!
For those who need it as well: go to file --> VI properties and select the "Execution" category. Here you can set the default non-reentrant execution to a reentrant form.
Message 8 of 9
(4,236 Views)
If the VIs are not reentrant, then only one instance of that VI can be in memory.  So it will cause a blocking between your two reads.  So the first one must finish the read before the second one can.  By setting these to reentrant, both calls to that read VI can have their own copy of the VI in memory and run in parallel.
Message 9 of 9
(4,216 Views)
