06-19-2012 10:28 AM
I need to edit a signal for an analog output daq port. I know there are really generic signals you can create, but I need to create a graph like this one to replay through my daq.
06-19-2012 04:04 PM
Hi ishironagasaki,
Are you able to save the data in a different format such as comma separated *.csv etc. This would make playback pretty straight forward.
From your png it would be possible to recreate the four waveforms but it would take alot of work. Also from your post it's not clear what details matter in these waveforms, pulse, amplitude.
There are tools to make pulses like you are showing such as the pulse pattern.vi under signal generation menu.
-SS
06-19-2012 04:09 PM
Can you capture and output that signal from the scope as some format? Replay that signal with the same timing out from the daq. May need to do some conversions from text to number to array/waveform.
06-19-2012 10:03 PM
I got the data straigh from the oscope so i'll see if i can save the data in a different format. The details need to be exact in these waverforms. The timing needs to be exact, and the amplitude needs to be exact. I know there are signal generation tools, but i need to be able to vary the magnitude at certain times.
I don't have an input port so replay is not an option.
06-20-2012 09:48 AM - edited 06-20-2012 09:49 AM
06-20-2012 12:00 PM
If I were to get the data in .csv format, how would I use the data in labview to replay the signal?
06-20-2012 01:01 PM
