Siemens S7 300 PLC and Labview Communication
I am attempting to communicate between Labview 7 and a Siemens S7 300 (CPU 314) PLC. I would prefer the communication to be over Ethernet or RS 232. Could you help me out with this implementation and let me know what additional hardware/software I may require for doing this.
Shameek
Message 1 of 15
(22,405 Views)
I never worked with Siemens PLCs, but a quick search returns quite a lot of hits.
___________________
Try to take over the world!
Message 2 of 15
(22,392 Views)
Thanks for the link. I have looked into quite a few of these and was wondering if the OPC server is an absolute necessity if I am using Ethernet.
Shameek
Message 3 of 15
(22,390 Views)
In my experience, most PLCs also have either a standard protocol (like Modbus) or a custom protocol which is either ASCII or binary based.
If it's something like Modbus, it's fairly easy, because you can find all kinds of implementations for these protocols.
If it's a custom protocol, then you will have to find the documentation and implement the protocol yourself using the TCP VIs. Implementing the full protocol is usually not a trivial task, but if you only want some simple commands (e.g. "Read DI", "Write DI"), then you might be able to do it, at least if the protocol is simple enough.
There's also a chance that someone already wrote VIs for that and posted them to the web or is willing to post\sell them.
___________________
Message 4 of 15
(22,380 Views)
I worked with a Seimens PLC before that used the Modbus protocol running over a TCP connection. Check the PLC's documentation as to what your communications options are.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 15
(22,370 Views)
I am using a CP-343 communications processor to connect the S7 300 to industrial ethernet. Now can I commnicate directly from Labview to the PLC? I still havent figured out where the OPC server comes in and whether it is an option or a necessity.
Shameek
Message 6 of 15
(22,350 Views)
Using OPC is an option.
Siemens has an the add-on ($$) library/FB  that includes code for enabling Modbus communication with S7 300 CPUs. I've never used it, but info is here.
<snip>
Our solution
With its MODBUS function block (FB) and the CP343-1 and CP443-1 SIMATIC S7 communications processors, Siemens can supply a proven solution for the integration of SIMATIC automation systems into other system landscapes. This function block enables data to be exchanged easily between MODBUS-compatible devices from different manufacturers and SIMATIC S7 stations from S7-300 and S7-400 systems.
</snip>
Fading out. " ... J. Arthur Rank on gong."
Message 7 of 15
(22,338 Views)
Thanks for your replies. So is this the way to go?
PLC > PC Using Ethernet card and the PLC comm module > OPC server on PC > Labview by Datasocket
Shameek
Message 8 of 15
(22,315 Views)
Hi Shameek,
We actually have a specific module meant, in large part, for communication between LabVIEW and OPC Servers. This is the Datalogging and Supervisory Control. With it, in your project you can easily add an OPC server for and set up your variables.  You could also use Datasocket but it is easier and better if you have a lot of variables to use DSC.
Here is a clip from this site on DSC: " It includes tools for logging data to a networked historical database, real-time and historical trending, managing alarms and events, networking LabVIEW Real-Time targets and OPC devices into one complete system, and adding security to user interfaces."
Stephanie
Message 9 of 15
(22,310 Views)
Shameek,
I know this is an old post, but I though I'd make you (and others searching the posts) aware of the MPI S7 Example posted on NI Community:
Marc
Message 10 of 15
(19,289 Views)
