Showing multiple values on front panel using array
For example, if I input "10" for number of datapoints, I want to see 10 hex and binary values all listed in a column. Right now, only 1 value shows up and all the previous values get erased 😞
Thanks!
(2,521 Views)
Accepted by topic author ABC123WEEEEE
You are not using a shift register to store the values in the array between iterations fo the For Loop.
This is a basic LabVIEW concept.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(2,518 Views)
     Wire the data outside the for loop for get an auto index array with all elements.
     You can check too: Tutorial: Arrays and Clusters.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
(2,509 Views)
