Showing data from mysql database to labview interface
Hi guys, I'm new with Labview, I'm working on a project and now I'm in the final step, I need to show some data from my website's database in my application (.exe) made with labview, is that possible? and if there's any tutorial will be helpfull!
Thanks and sorry for my English.
Message 1 of 8
(4,959 Views)
Do you have the database toolkit?  Look in the Connectivity palette for a set of Database VIs.  As long as you know the connection settings to the mySQL server, it is fairly simple to query a set of rows and columns.  Examples are included with the toolkit.
If you don't have this toolkit, there are other toolkits that use the same ActiveX calls.  One that i have use was called LabSQL.  There are probably others that I am not familiar with but try one of these and post back if you have additional questions.
aputman
Message 2 of 8
(4,917 Views)
Do you have direct access to the database or is the LabVIEW application going to have to make calls to your website in order to get the data?
Message 3 of 8
(4,905 Views)
sadly I don't have connectivity toolkits so I will try labSQL, many thanks for help!
Message 4 of 8
(4,876 Views)
I do have a direct access to the database.
PS: Sorry if I wrote two messages, but I didn't know how   to reply to both messages in only one message.
Message 5 of 8
(4,875 Views)
Just write your message addressing each person.
Aputman,
I want to tell you this.
Jacobson,
I want to tell you something different.
Message 6 of 8
(4,871 Views)
Aputman,
Jacobson,
This way is more informative anyways, unless you include a quote of the person you are replying to.  The two separate posts that the OP made above give no indication about to whom the reply is addressed.
aputman
Message 7 of 8
(4,868 Views)
@aputman wrote:
Aputman,
Jacobson,
ok Thanks guys again sorry for spaming.
RavensFan,
Thanks also for help.
Message 8 of 8
(4,859 Views)
