Show/hide the filter events node inside a event structure
Hello everyone,
I am trying to find out, as the title suggests, how to make the filter events node inside a event structure visible as it seems that the default setting for the event structure is not to show it.
Thank you.
(6,330 Views)
I don't think you can control its visibility at all. It's either there (if your event is a filter event) or it's not (if it's a notify event), so to make it visible, you need a filter event.
___________________
Try to take over the world!
(6,325 Views)
Accepted by Fixxer
In order to show the filtering nodes, you need to select a filtering event. These are the ones ending in a question mark and having a red glyph.
Compare "Key down" vs. "Key down?" for example.
(6,323 Views)
Ok then, I understand now.
Thank you for your prompt responses.
(6,320 Views)
You can find all possible events in the event configuration dialog.
(6,310 Views)
