Show biggest index in array with value "True"
Is it possible to show the maximum index number with value "true", like shown underneath?
I can show the value on what index the series of "true" ends with the "Array Max & Min" function, but when there is
one False between those True's, it will show the index of the True left of the False.
I don't need to know the size of the array, because it has to stay 8
File is attached
(2,442 Views)
Accepted by topic author Stef_vl
Hi Stef,
here you go:
(2,439 Views)
Thank you so much for the fast and perfect response !!! Kudos are well earned 😉
(2,436 Views)
