Should i keep a database connection open?
Hi
I am currently working on a project where we have various measuring stations sending data to a central analysis machine. We decided to shift to SQL server as our permanent storage back-end.
The question is this: should the measuring stations maintain a constant connection to the database or should they connect/disconnect as necessary?
Keeping the connection open saves on the ~300ms connection time and with possible multiple consecutive db access this could become a problem. Also if I keep the connection open I have no way of knowing when the station loses connection with the DB until I actually try to interact with it.
So do I keep the connection open with the probable logic overhead of establishing whether the station is connected and reconnecting if necessary or do I simply open and close the connection as needed, obviating the need for testing, but incurring a ~300ms time penalty on each DB operation?
I look forward to your opinions and advice.
Tjoppi
Message Edited by tjoppi on 02-24-2010 05:20 AM
This represents my opinion and may have no bearing on reality
(8,769 Views)
Hi Tjoppi
How often do you access the SQL database? If you write/read every second I would definitely keep the connection open. If you only access the DB every hour I would probably close the connection.
In most cases I would tend to keep the connection open as long as your application runs.
Just my 2c.
Daniel
(8,754 Views)
The DB receives data from multiple connections about every 2 seconds although some of these connections only send data once every 23 seconds.
(8,747 Views)
Accepted by topic author tjoppi
When sending data every 23 seconds I would keep the DB connection open. As you said, you might have to do error handling when the write task fails due to a broken DB connection.
(8,744 Views)
Great!!! found that i can save some 300 - 800ms if i keep the connection open.
Kudos always welcome for helpful posts 🙂
(7,761 Views)
