Shortcut to jump up or down in an array constant?
Alright, so lets say I need to create an array with 10 elements. After I have create an empty array and enlarged to 10 elements I click to the first index, type the content, then click to the second index, type, click, type, click aaaargh.
Its so disturbing that I always need to touch the mouse when I want to change which index I am editing right now. Do we have a shortcut for jumping up and down between the elements?
Also deleting items from an array is a huge pain in the butt... rightclick -> data operation -> delete element. Once you need to delete 100 elements from an array you need a good amount of coffee and / or sedatives.
Please help me out by communicating these secret hot keys.
thanks.
(5,994 Views)
There are no magic shortcuts, but there is an idea for it - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Tab-between-array-control-constant-elements-during-edi...
Personally, I don't have too many array constants and I don't edit arrays all that often. I agree that it's a cumbersome process and could be handled better, but it's usually a relatively rare annoyance. If I do have a case where I need to do a lot of work, I will usually move the data (either with code or with the right click copy or export options) to a more favorable environment like Notepad or Excel, do the work there and then move it back.
___________________
Try to take over the world!
(5,987 Views)
I do the same... and its a pain in the back. Thanks for linking the idea.
(5,971 Views)
Accepted by topic author 1984
A tip for entering value into the array.
Instead of creating a constant array and keep using the mouse to enter element you can do this way.
  • Create an array control in the front panel
  • size according to the number of elements you want to enter
  • Press Ctrl+M (Switch to run Mode) and enter the value in the 1st index, then use Tab to go to the next index sequentially forward and Shift+Tab to go backward.
Finally once everything is done change the control to a constant. Isn't this simple Smiley Wink
(5,958 Views)
Holy cow!!!! And it works 🙂
http://goo.gl/Vx6TnH
(5,940 Views)
Well I just learned something new.  I will have to remember that next time.
(5,928 Views)
