Getting outputs of different lines in MIMO( Multiple Input Multiple Output) using tdms file viewer
I am taking multiple inputs from a BNC 2120 using the DAQ assistant and viewing them through a TDMS file viewer on output.
The graphs that i get in the tdms file viewer shows all the signals on the same graph. The way i need them is to be on seperate graphs so that i can perform a more precise analysis of the signals.
(2,719 Views)
Then you might just have to make your own.  Reading from a TDMS file is simple.  Just look in the examples.  You can make whatever setups for graphs you want from reading the data.
(2,698 Views)
