Shortcut key insert onto wire segment
When using the shortcut for block diagram insertion (ctrl-space, then ctrl-i), the new vi is inserted into the earliest instance of a wire segment, not necessarily the one selected.
This is irritating because I often need the vi inserted after the wire is split (thus inserting onto only one branch of the wire).
(2,443 Views)
And?
I think you should make a suggestion on the LabVIEW idea exchange to have the behaviour modified.
Epictetus
Antoine Chalons
(2,439 Views)
