Shift register initial value
I wrote a simple program with a while loop that contains a shift register that save the previous iteration value.  When I stop the program and restart the program again, I thougth the shift register's value will get reset to 0 (for a I32 data type)?  Apparenetly, the shift register retains the value from the previous run before I stop the program.  Why is that?  Why won't the shift register reset?
Message 1 of 22
(10,946 Views)
Because that's by design. It's also documented in the LabVIEW Help. Did you look in there?
An Uninitialized shift register is actually quite useful in creating a LabVIEW 2-style global variable, AKA functional global, AKA Action Engines.
Message 2 of 22
(10,940 Views)
If you would like to reset the SR without moving a wire or other trivial change, just force a recompile by pressing ctrl while hitting the run button.
Message 3 of 22
(10,927 Views)
Just wire a constant with a value 0 to the SR before entering the while loop.  Problem solved 😉
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 4 of 22
(10,911 Views)
See the picture (not a snippet)
Paolo
Message 5 of 22
(10,892 Views)
Darin,
That's exactly what I am looking for.  Can you point me the reference that talks about ctrl+run and recompiling?
Message 6 of 22
(10,877 Views)
This and many other fine keyboard shortcuts is available here:
http://www.ni.com/pdf/manuals/373353d.pdf
Message 7 of 22
(10,858 Views)
@jyang72211 wrote:
Darin,
Of course, that won't solve the issue when you're running the VI normally. Unless you explicitly want the shift register to be uninitialized?
Message 8 of 22
(10,856 Views)
That mask will not prevent us from finding the person who offered that extra length of rope.
Ben
Jyang,
Please see the link in my signature about "Race Conditions" to learn more about SR and how to exploit them.
Message 9 of 22
(10,844 Views)
Telling someone there IS a bucket of Truth is not the same a pushing (or nudging) them in.
Message 10 of 22
(10,827 Views)
