Shift Register Alternative
Accepted by endlessOranges
POC Code for doing this with Data Queue pt by pt
Note there is only 1 buffer alllocation for the data (Sort operates inplace)
"Should be" isn't "Is" -Jay
Message 11 of 13
(1,198 Views)
Maybe fixed size queue and Lossy Enqueue Element will work also. You can always get all elements in the queue with Get Queue Status.
I have no idea if this is faster than Data Queue Pt by Pt.
Message 12 of 13
(1,198 Views)
Thank you! I worked with what you posted and tried tweaking things around to what I would want I seem to have the hang of it. The system is currently running so I can't implement it at the moment but I'll try later today or tomorrow morning and update whether I was successful.
Message 13 of 13
(1,179 Views)
