SharpPcapWrapper.dll Error in LabPCap Project
I needed to retrieve data from the UDP header, such as the MAC address, port, etc. After some research, I discovered I could do this with the attached library.
The project is working very well. But when I add the file 03 LabPcap Example Capture Infinite Packets.vi to another project, flush.vi does not work.
When I get to the source of the error, I see that it cannot add the SharpPcapWrapper.dll file to the .net reference in the Obtain Ref.vi file.
I received the error you can see LabpCap Error-1.png and LabpCap Error-2.png. I added the problem-free version with LabpCap Error-3.png.
Does anyone have any ideas?
LV 2024
Message 1 of 1
(370 Views)
