Example code to control BK precision 9200 series power supply programmatically.
Hi....
Can anyone send an example code for controlling the BK precision 9200 series power supply which needs to have a graph to represent the output current, voltage and current values along with data logging and export of that output data.
Thankyou
(1,826 Views)
Download and extract the content from BK Precision 9200 Series Power Supply - Ethernet, IEEE 488.2 (GPIB), Serial Driver for LabVIEW
to <LabVIEW>\instr.lib. Examples are provided in the zipped folder.
https://tmesystems.net/
(1,775 Views)
Hi ZYOng
I am using BK precision 9202B power supply, i am try to set voltage and current value using labview,
You already provided this " Download and extract the content from BK Precision 9200 Series Power Supply - Ethernet, IEEE 488.2 (GPIB), Serial Driver for LabVIEW "
But it seems some function is missing
Can you please provide any example labview VI file for to set voltage and current value
Thanks in advance
Ashok G
(527 Views)
Hi Ashok,
As it seems ALL the subVIs are "missing"…
Did you install that device driver correctly? (How and where did you install the driver?)
(521 Views)
Hi GerdW
I not install any driver
Can you please suggest me a driver for that
Ashok G
(505 Views)
Hi Ashok,
But you noticed message #2?
What's wrong with the provided driver?
(494 Views)
