Shared variable reconnection time is slow
I'm communicating between cRio and PC using shared variables. Connection is working fine, but I'd like to improve the functionality when connection is lost between the two.
When I disconnect the Ethernet cable between cRio and PC, my program notices this by monitoring errors.
When I connect the cable, clear the errors and try to open connection after a while, the program can establish connection, but it takes some time, maybe 30-60s from connecting the cable.
Are there any actions that I could do to make re-connection faster?
Thanks.
(1,534 Views)
My honest advice:  Stop using Network Published Shared Variables.  They are slow, very insecure (anybody on the network could update them), and have caused me so many very weird race conditions.  Instead, use a direct TCP connection to pass data back and forth between the cRIO and PC.  I do this with a loop specifically for this communication on each side an use a queue or User Event to pass the data on to whoever needs it.  The loop can detect a disconnection (have an error) and close the connection and go back to trying to establish a connection (cRIO as the server uses the TCP Create Listener).  Assuming you are using static IP addresses, I have had disconnections and be able to reconnect seemingly as soon as I reconnect the cable.
(1,504 Views)
In my case there is no possibility for security threats but there's also no possibility to change to direct TCP at this point.
I just would like to know if there is any way to get reconnection a bit faster when using shared variables. Is there some reset feature/process or something like that, which would speed up the reconnection?
(1,500 Views)
Are Shared variables the same as network shared variables? (I haven't used them), if so, there's a Read with Timeout that you can use.
Qestit Systems
Certified-LabVIEW-Developer
(1,482 Views)
