Shared variable on LAN
Have a .llb file with top level user interface,  I need to share a single dynamic variable with another PC in another lab.  The 'writer / server' PC will be running for an extended time before and after the variable is needed on the other machine (client).
There are several methods to share data; last time i did this was using Data Socket which was not too robust as I recall.
Suggestions and recommend method to use for doing this are welcome.  I do not have a project assembled for the .llb file.
Speed across the network is important but we do have a high-speed network
(3,130 Views)
Accepted by topic author bonnerupc
My recommendation is to use a simple TCP Client/Server communication.  When the server needs to pass on an update, it sends the message.  If you want a good framework, have a good look at the STM (Simple TCP Message) library.
(3,119 Views)
Thanks much.  Yet another method to share data...
Looks like a good and simple solution; I'll let you know how it behaves.
Chris
(3,112 Views)
GREAT method; very clean, simple and fast.
Very much appreciate the link.
Chris
(3,095 Views)
