cRIO 9023 not booting correctly
I have a crio 9023 that is failing after installing any software to it. Attached is the console output:
                            cRIO-9023 Boot
Copyright 2008-2009 National Instruments Corporation
Bootrom version: 2.1.2f2
Creation date: Jan  7 2010, 16:07:25
f
Press any key to stop auto-boot...
1
0
auto-booting...
boot device          : usbms
unit number          : 0
processor number     : 0
host name            : lvrt
file name            : /c/ni-rt/system/vxWorks
flags (f)            : 0x8
Attaching to USB disk device...
USB mass storage firmware version: 1.0.0f2
Using SST NANDrive
Reliance File System Driver
Datalight Reliance v3.2.2 Build 1376BV
VxWorks Edition for ppc603
Copyright (c) 2003-2008 Datalight, Inc.  All Rights Reserved Worldwide.
Loading /c/ni-rt/system/vxWorks...2885248
Starting at 0x10000...
USB disk /c þ
                            cRIO-9023 Boot
1
0
auto-booting...
boot device          : usbms
unit number          : 0
host name            : lvrt
flags (f)            : 0x8
Using SST NANDrive
USB disk /c þ
 (it reboots again after this point and starts over)
Any ideas what to do? The status LED3 is constantly lit (indicating critical error - contact NI).
I have reinnstalled, formatted etc etc etc but to no results. (safe mode works) All IP settings are OK. This is only happening to this controller, and the controller is new out of the box. As said, installing the same software to another 9023 controller gives no issues. (We have currently 8 other 9023's running the same software as well)
(3,179 Views)
I recommend to do exactly what the LED tells you to do: Critical error, get in contact with NI. Especially since the system is new and out of the box. Send it back and get it replaced...
Regards, Jens
Kudos are welcome...
(3,131 Views)
Well to finish how this went:
The cRIO was a spare part we have as backup for a machine. It has been stored 6 years.
It is a critical component so we always have these in spare to be quickly replaced in case of system failure. So we had a lot of issues when the spare part did not work, when we got a system failure after 6 years at that specific system - where the point of having the spare part is to have as low downtime as possible.
NI said it had exceeded the 5 years warranty so it does not help if it is straight out of the box or not.
The end customer has lost faith in NI due to both an invoice for repair costs, but the costs for the system downtime are bigger. They refuse to pay repair costs for an unopened spare part.
So in the end I am upgrading to a newer model instead of repairing this, have ended up having a customer that has lost faith in NI, got furious about repair bills, and is scared of system downtime even if we buy an additional cRIO for spare part use per machine.
(2,952 Views)
Accepted by topic author Corny
Case got solved and a good solution was found with NI.
Customer happy 🙂
(2,941 Views)
