Shared variable deployment- undeployment process in LabVIEW
1. Is it require to deploy and un-deploy shared variables every time when application starts and exit ?
2. Is it OK , if I deploy shared variable for one time only and then never deploy shared variable on same PC.? (Deploying shared variable for first time and then re-starting of PC ,Does require deployment of shared variable again?)
Thanks !!!!
(2,956 Views)
Accepted by topic author piZviZ
  1. You don't need to deploy / un-deploy variables every time the application starts, though the variable probably needs to be deployed at least once.
  2. Once you deploy a variable, it will remain deployed and persist after a reboot. You can verify which variables you have deployed using the Distributed System Manager.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(2,935 Views)
