Shared indicator
I have a VI which produces different kind of data like String, DBL, Int, Float depending on the test case. I also have an indicator for every type of the data. The data comes to only one indicator at a time.
My question is: Is it possible to pass the data into the single indicator? The indicator would show at least String, DBL, Int and float data types? It would simplify my Front Panel.
BR,
Jick
(3,118 Views)
Maybe I can try to format every kind of data into string...It could be worth of trying..
Any other ideas?
Jick
(3,113 Views)
You will have to type cast everything into one format. String will probably be the easiest.
Tim
GHSP
(3,096 Views)
I prefer Clusters. You can you cluster for all your existing indicators. you have only one cluster indicator on the FP and in the blockdiagram.
(3,085 Views)
