Shared Variable based on Array of cluster
I've created a shared variable which is based on an array of cluster (typedef). The cluster only contians two double elements for x-y coordinates of a point.
Everything seems working until I found the shared variable can only hold the first two elements when I pass an array to it.
Are there any settings I've missed?
Yan
(3,570 Views)
Show us how you are building your data and sending it to the shared variable.
(3,556 Views)
Data is simply created and directly sent to SV.
The difference during defining the SV is:
Normally, when define an array SV, it allows to change the "Number of elements" (default as "2").
However, when define a typedef array SV, the option is gone. Does it then use the default number "2" as the number of elements?
(3,542 Views)
You defined the Shared Variable as a Single Element FIFO.  That means it can only hold 1 element.
What can be confusing is that you defined your shared variable as an array of clusters, as opposed to the cluster itself.  If this was a multi-element instead of single element FIFO, then you could theoretically wind up with an array of arrays (of clusters).  I don't know if the shared variable engine can handle that.  In general, you can't have an array of arrays in LabVIEW.
(3,535 Views)
