Shared Variable Not Deploying
I'm having a hard time getting the shared variable to deploy on the C root of the computer.
The following error comes up each time I try to deploy the Lib
Deploying Untitled Library 1\\192.168.0.12\Untitled Library 1 deployment failed (error: -1967362042, IAK_SHARED:  (Hex 0x8ABC7006) Unable to start service.)
I've tried uninstalling and installing labview and it's components.
I would appriciate any help.
(4,616 Views)
Hi Dfallah,
Please check out this KB: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LgKSAU&l=en-US
Do those steps allow you to deploy your library?
Best,
Joey S.
Senior Product Manager, Software
(4,587 Views)
Joey,
Thanks for the response.
The service will not start. I get the following error attached.
The document suggest reinstallation of the DSC Module, problems is I do not have DSC installed. We do not have a lincense for it.
Dan,
(4,581 Views)
Hi Dan,
So when you attempt to start the National Instruments Variable Engine, you get error 1068?
Let's try following these steps too:
http://digital.ni.com/public.nsf/allkb/96A6A02DA3BEC8D286256B2000715EE9?OpenDocument
Let me know how it goes!
Best,
Joey S.
(4,556 Views)
Hi Joey,
Tried your suggestion.  Now I'm down to National Instruments mDNS Responder Service having a 1068 error and I can't seem to find anything online as to what it's dependency's are.
dan,
(4,550 Views)
Are you able to find this file on your computer?
C:\Windows\System32\nimdnsResponder.dll
If not, it is possible the installation for the service failed. To workaround this, you can run the .msi with the same name to install the service.
Have you tried deploying to locations other than the C: root drive?
Joey S.
(4,539 Views)
