Shared Variable Error -1950679023 in LabVIEW 8.6.1
Hi Brian,
Good Morning and I hope your well today.
Thanks for the post.
I can't confirm that the LabVIEW RT requires the dll to be updated as well, but it certainly does appear to be the case.  However, I feel this would be expected.This is because the exe will use the LabVIEW Run-Time Engine, which doesn'tuse the same files as the Development Environment. Thus, updating LabVIEW will not affect the LabVIEW Run-Time Engine.
The reason for naming the previous dll to ".bak" is to allow the user to easily undo the update. So as long as you have a copy of the original dll on your development machine I dont see why you can't delete the original.
To automate the update you could create a script or exe to run on the machine to update the dll.. have you mananged to do this, please let me know if you need any further support.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
Message 21 of 26
(2,542 Views)
I'd just like to quickly add that after installing LabVIEW run-time 8.6.1 on the machines without LabVIEW I also had to edit nitaglv.dll in C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\8.6 (as described at: http://joule.ni.com/nidu/cds/view/p/lang/en/id/1255).
Before I did this although the programs ran ok on my development machines, when built into an exe and installed on different machines the variables still didn't bind properly.
Hi Sarah,
Sorry for chiming in to your old thread. But  i am also looking for a solution to my problem. I am exactly on the same spot as described in your second paragraph. The shared variables will run properly on the development machines but when built an exe the variables didnt bind properly. I always get the error 1950679023 even though i installed the patch file.
I wonder what remedy you did. Would you mind sharing how you fix the problem. Thank you very much.
regards,
Message 22 of 26
(2,376 Views)
If I remember correctly I had to find nitaglv.dll on the machine the exe was actually going to run on (it's in C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\8.6 I think, if not just do a search for it) then replace that with the patch too.
After that it all seemed to work fine.
Hope this helps,
Sarah
Message 23 of 26
(2,359 Views)
Please see this & this.
Also, somewhere i read that LV 8.6.1 has got this issue fixed.
What is your LV version?
- Partha ( CLD until Oct 2027 🙂 )
Message 24 of 26
(2,356 Views)
Dear Sarah,
I owe you oneSmiley Surprised..Thank you very much.
I only replaced the patch file on  C:\Program Files\National Instruments\LabVIEW
8.6\resource. Thus i cant make the exe file run properly.
This took me a while to figure this out. Thanks a lot.
regards,
Message 25 of 26
(2,336 Views)
I came across this problem and solved it in the following way.
Shared Variable enough to move from one place to another as shown in the figure.
Message 26 of 26
(1,484 Views)
