Share cluster data between 2 timed loops
In your situation, the simplest and cleanest solution is to wrap your data into a data value reference and use that in your running loops.  This results in very little extra code or subVIs and will probably outperform the functional global.  It is also a lot safer to use, since it gives you a global mutex any time you access your data.  As with the functional global / action engine, it is possible to abuse it and get race conditions, but this should not happen if you keep all data read/write inside the in-place element structure you use to read/write the data and do not pass any of the data outside that structure.  If you do pass data out, do not pass it back in.  These two simple rules will keep you pretty safe.
Message 21 of 23
(799 Views)
I thought the whole idea behind n FG was not speed, but reliability - i.e., no copies of data being made so no chance of stale data?
Bill
CLD
(Mid-Level minion.)
Message 22 of 23
(791 Views)
That will depend upon your implementation of the functional global.  If you pass the data out of it, you make a copy.  With data value references, it is much easier to avoid copies.
Message 23 of 23
(788 Views)
