Setting control default values
Hi Jim,
This example may not be neat enough, but it should be able to give you an idea of how .ini is used for your matter.
Play with the configuration file VIs, you will be able to come out much better and complex one, including saving/ retrieving of arrays, clusters etc.
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 11 of 11
(553 Views)
