Setting Up Analog Output using DAQ.mx function
LabVIEW newbie here,
Currently attempting to create a VI that continuously samples, processes and writes a signal. I am unsure how to set up the analog output. I believe the analog input was correctly implemented. Can anyone provide some guidance? I have attached the VI for your reference.
Also, can any of you ensure that the approach I took will adequately perform what I want? Any tips are greatly appreciated.
Thank you all
(3,188 Views)
Why do you keep creating new posts for your same topic/questions? This one is already the third. You should keep the topic ongoing in a single place.
The two other previous posts were created here:
http://forums.ni.com/t5/LabVIEW/Producer-Consumer-Model-to-perform-continuous-output/m-p/3602955#M10...
http://forums.ni.com/t5/LabVIEW/Simultaneous-Analog-Input-and-Output-using-myDAQ/m-p/3602156/highlig...
Ask an admin to merge together these posts, or at least keep the conversation ongoing in the last one, do not create a 4th post!
(3,126 Views)
