Ethernet IP, Invalid Segment Type Error
I'm wondering for those who have used the Ethernet IP toolkit, if there are any common causes for the error:
Error -251723760 occurred at EthernetIP Tag Read BOOL.vi;
Details: CIP Error - Extended status may be available
CIP Status: 0x4 (Invalid segment type/IOI)
Right now I'm simply trying to establish and confirm a connection to the PLC so code wise, I'm just trying the various instances of the Ehternt IP read tag VIs with a network path and tag.
From what I've seen, this could be caused by the formatting of the tag and/or the number of elements read, type of element (bool, SINT, etc) but I haven't seen any consistent answer, probably because this is likely an error specific to a given situation so I doubt there's a one-size-fits-all fix, but if anyone has had this error before, I'd like to hear how you fixed it, thanks.
I saw my father do some work on a car once as a kid and I asked him "How did you know how to do that?" He responded "I didn't, I had to figure it out."
(10,901 Views)
Nevermind, it was a tag formatting problem,
PREFIX.TAG, I had the wrong PREFIX
(10,884 Views)
Can you share how you fix the problem? "Tag program",can you give a demo of right tag?
(10,255 Views)
The scheme we were using for that system had tags such as Tester1.TagName, Tester2.TagName, etc, so that all the tags names were consistent and we could simply append a prefix onto it to update EthernetIP tags for a specific tester. I was trying to read a tag which did not exist on the PLC, for instance I may have been trying to set Tester3.TagName when there was only a Tester1 and a Tester2.
The error that occurs when you try to access a non existent tag is (or at least at the time was):
Since that error was based on a more generalize CIP error code, LabVIEW had no way of knowing that the cause of the error was because the tag didn't exist, it only knew that a 0x04 CIP error occurred, which is why it didn't throw a more obvious error such as "the tag is invalid".
(10,249 Views)
Thank you for your reply,I know why the error ocurs.
From "NI-Industrial Communications for EtherNet/IP Help",it says Tag Name's format "MyObjectTag.InputDataItem.Control[3]",so I write "PROGRAM.OP10.EOL_B[0]" to tag name,the error occures.
But when i use OPC communication in the OPC Client,tag address'fomat is "PROGRAM:OP10.EOL_B[0]",it works.
then I try to write" PROGRAM:OP10.EOL_B[0] "to tag name by EthenetIP communication, it works.
From the above test, I doubt whether  NI'help is  wrong, I just change"."to ":",it works.
Anyway ,I hope the test can help other people.
(10,239 Views)
