SetThreadPreferredUILanguages
Hi
has anyone used the windows API SetThreadPreferredUILanguages to change the locale of a Labview User Interface, any help on using this API would be great
Thanks Andrew
(3,606 Views)
Andrew,
You will need to use the Call Library Function Node to call into the windows API. There are a couple of examples of using the Call Library Function Node here and here. You may also find this information on the Microsoft website useful.
Elizabeth K.
National Instruments | Applications Engineer | www.ni.com/support
(3,563 Views)
