Set xy graph display format
For an an xygraph how do I programmatically set the x-axis display format type to absolute time, and then specify 24 hr, HH:MM:SS? The property node options are not obvious to select the required combination of values.
Thank you.
Girish
(1,786 Views)
Accepted by topic author girish53
Thank you.
Girish
1. Create a numeric constant (or control\indicator) and right click it to select "Display Format...".
2. In default editing mode, select how you'd like the formatting to be.
3. Switch to advanced editing mode, and copy the result ("%<%H:%M>T")
4. Use a property node to set the format string of the scale:
(1,784 Views)
