Set system time or current time on x scale of waveform graph
hello................ I am tring to set current or system time on X scale of waveform graph but how i can give system time to x scale please guid me. I set x scale from display format in hh.mm and AM/PM. But at but how I can initialise  system  time to x scale.
(3,014 Views)
Accepted by topic author shubhangi
Hi Shubhangi,
To set the system time on your X-axis, Go to graph properties, Display format and select absolute time. In that set System Date and Time. To get the current time, use the get time function and set the Offset Property value of the X-scale to current time. Check the attached Example. Refer this link for more information.
Nitz
(Give kudos to Good Answers, Mark it as a Solution If your problem is Solved:smileywink:
(3,007 Views)
thanks for ur answer. it working and my problem has been solved.
(2,998 Views)
