キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Set own X axis data point in Waveform Graph
Here it goes,
now im trying to format my waveform graph in LabView.
i have my own set of data which is currently in 2D array and it has 1 colume and 11000 row of data.
i want to use this data to be my X axis.
any idea on how should it be?
0 件の賞賛
メッセージ1/8
4,503件の閲覧回数
And what do you want to use for your Y data?
0 件の賞賛
メッセージ2/8
4,497件の閲覧回数
19475i221ACCB734425D53
Something like this.
im able to plot the graph now with Column Y and Z but i cant find ways to set the X axis with the X column.
is it possible to do it?
0 件の賞賛
メッセージ3/8
4,487件の閲覧回数
0 件の賞賛
メッセージ4/8
4,476件の閲覧回数
yes, i want it to be show in order
i have seen these 3 threads but it seems that i cant find the solution i needed.
but firstly, is the scales in waveform graph editable?
i, still exploring the property node trying to find ways of doing it, but still cant find it thought.
0 件の賞賛
メッセージ5/8
4,461件の閲覧回数
You cannot edit the scales the way you want. Neither the chart, graph, or XY graph allow fot arbitrary or text scales. The links above are the only way I know of.
0 件の賞賛
メッセージ6/8
4,456件の閲覧回数
crap.
so there's is no other way of displaying the values i want for X axis? cos in the end, i might have to export the graph out to microsoft word.
from the method i see, after exporting, the X axis value in gone as it is not together with the graph.
0 件の賞賛
メッセージ7/8
4,448件の閲覧回数
0 件の賞賛
メッセージ8/8
4,437件の閲覧回数
