Set control default values programmatically (arduino distribution)
So I know this has been discussed before but I have a unique situation.  I will be downloading code to Arduinos using the Labview Compiler for Arduino toolkit.  I would like to programmatically set some default control values on each Arduino using a Labview GUI.  The Arduino toolkit I am using has a compile VI that takes a VI, compiles it, and then downloads it to the Arduino.  How can I change the default value for the VI's controls before it's compiled and downloaded?
Message 1 of 11
(10,391 Views)
If it is a LabVIEW VI, set the Controls as you want them to be, right-click the Edit Menu (while viewing the Front Panel), and choose "Make Current Values Default".  Note that if you've selected a Control, the message will read "Make Selected Values Default".
Message 2 of 11
(10,375 Views)
Thanks but I want to do this programmatically without having to open the VI.  I will have a GUI that will download the program to multiple Arduinos and the control values will be different for each one.
Message 3 of 11
(10,359 Views)
Accepted by topic author NiAchilles
Have you tried using property nodes to set the values and then method nodes to "make current default" and save the VI?
Message 4 of 11
(10,349 Views)
That worked!!  You rule.  I had to add an error handler because I kept getting an error message from the Set Values as Default block saying that the target VI was not in edit mode, even though it was.  Anyway it set the control default values successfully so I just ignore the error.  Thanks for the help!
Message 5 of 11
(10,315 Views)
Not sure why you would be getting that error, but I'm glad it's working for you. And since we're on the subject, a simpler alternative way is to use the Ctrl Val.Set method:
Message 6 of 11
(10,297 Views)
Hi to all,
       I don't know why i get the error message like "vi is not in edit mode"?, cn you explain me this? and also is that possible to visualise the modified values in user panel? bcoz everytime i need to see the values befor i set in the user panel
Message 7 of 11
(9,466 Views)
hi paulrobinson,
Are you running the program and getting the error using the example program linked earlier to this post?
Since this forum hasn't been active for 2 years and a solution has been marked, I would recommend you starting a new post to get more insight on what you are seeing!
best,
Cici Z.
Applications Engineer
Message 8 of 11
(9,453 Views)
Hi cici.z,
      First of all thanks for your reply, and i got a slution for this problem by using get and set values.
paul
Message 9 of 11
(9,436 Views)
Hi cici,
       Here i have attached a vi to read and write the data in a same ini. file but when i write the data in a same section it is not appending instead of that it creating a new section how can i do this part?
Paul
Message 10 of 11
(9,401 Views)
