Set active cursor position
I think the problem may not be with the code but with the cursor properties. If you have it set to snap to a plot, then when you try to set it the cursor will snap to the x-position of the nearest point on the plot and you will read back a value different than what you set. If you have the cursor set to "free" then you should read back exactly what you set. The cursor properties are set
Richard
Message 11 of 13
(746 Views)
I also test the cursor set to "free" and the results are also different!!
Sílvia
Message 12 of 13
(724 Views)
I can't test your code because it is too complicated and I don't have all the parts needed to run it. Can you make a simplified example to demonstrate the behavior and post that?
Richard
Message 13 of 13
(717 Views)
