Set active cursor position
I'm trying to set the value of a cursor in a xy graph, but the value that I write is different that the one I read, like you can see in the picture.
Does anyone know why?
Thanks for your help,
Sílvia
Message 1 of 13
(5,675 Views)
Silvia,
I made a test and it looks ok in my LabView 2010.
What Labview version are you using?
Paul
Message 2 of 13
(5,666 Views)
Paul,
I'm using LabVIEW 2010 also...
The fact that the numbers have a high number of decimals can influence?
Sílvia
Message 3 of 13
(5,658 Views)
I used exactly the same value as you did and it works.
Interesting...
Message 4 of 13
(5,653 Views)
Strange!!
I attach the program, if you can run the program.
I don't know if you will understand everything, but in principle you only need to press start and add the files that are in "Tests.zip".
Once again thank you,
Sílvia
Message 5 of 13
(5,646 Views)
Silvia,
It still looks ok to me.
Please see attachment.
Paul
Message 6 of 13
(5,637 Views)
Even more strange!
But is good, maybe the problem is the computer, that's a little old, tomorow i'll experiment in another.
Many thanks,
Sílvia
Message 7 of 13
(5,633 Views)
It still not working, and I test in two other pc!
I don't understand what may be happening..
Sílvia
Message 8 of 13
(5,610 Views)
Hello silvia,
Which version of LaBVIEW are you using ?
When you said that you did try on two other computers, did you try the same code ?
Have you juste tried to make a simple example with a XY plot and to use the cursors property node to get the X value and compare it ?
Yannick.
Message 9 of 13
(5,578 Views)
I'm using LabVIEW 2010, and I tried the same code in other computer. The same code which Paul also tried and run correctly in him pc.
I also tried another program, more simple, and with it sometimes I have the correct values, sometimes don't. I also notice that if I decrease the dimension of the array the program run better. I think that the problem can be in the graphic card, what do you think?
Sílvia
Message 10 of 13
(5,555 Views)
