Set Zero
At the moment i am putting values of a force sensor in a graph.
When i am going to use the sensor the start value should be set to zero so that i know how much force is applied.
Does anybody know a function for setting the current value to zero?
kind regards,
Jan
Message 1 of 9
(5,180 Views)
Hi Jan,
simple "ZERO" feature: store a force value in a shift register and subtract it from all following force readings…
Message 2 of 9
(5,174 Views)
i haven't found this feature yet
can you maybe show where i can find it?
Message 3 of 9
(5,156 Views)
Hi Jan,
"shift registers" are a VERY BASIC LabVIEW concept. You find explanations in the LabVIEW help!
Message 4 of 9
(5,139 Views)
yeah i know a bit about the shift registers, but can you lock a value?
because if the values change the 'locked' value should be subtracted.
Message 5 of 9
(5,128 Views)
Hi Jan,
Yes, sure!
You could use a case structure (or a select function) to decide, which value to write into the shift register for the next iteration: use a new one or keep the previous one…
Message 6 of 9
(5,123 Views)
Here's one possible way. This is really basic so I recommend continuing with the tutorials...
(Be aware of mechanical action settings too)
Message 7 of 9
(5,106 Views)
What you are asking for is often known as a "tare" function.  That term might help you when searching the forums.
Message 8 of 9
(5,082 Views)
Often does sensors have a tare function...
If it's a pure analog value, it won't. If it has a communication protocol, it's likely.
Message 9 of 9
(5,064 Views)
