I can confirm this behavior. Setting the execution system to "user
interface" helps a bit, but there is still a big difference.
I get a feeling it has something to do with window messages, perhaps
WM_PAINT or something, that is handled differently if a VI is not
frontmost... But what do I know...
Don't know if it should be called a bug, but it sure is something that could
be optimized.
Wiebe.
"Rob Calhoun" wrote in message
news:506500000008000000AEF20000-1079395200000@exchange.ni.com...
> I'm posting this issue to the forums prior to submitting a bug report
> to ensure that the problems I'm having are reproducible. To reproduce
> this bug, you're going to have to be an advanced user with a large
> project (hundreds to thousands of VIs) as the performance problem is
> related to the number of VIs loaded.
> The issue is the increasingly poor performance of the LabVIEW 7.1
> Development Environment as the number of VIs in memory increases. The
> actions affected include switching between front panel and diagram,
> saving a VI, copy and paste, clicking a menu, and the mysterious time
> spent (compiling? editing the runtime menu? changing the toolbar
> state?) between pressing the run button and when the code actually
> starts executing. Scrolling and, interestingly, copying via a
> control-drag are not affected. Running time of entirely on-diagram
> code does not seem to be affected.
> These problems are quite severe and significantly decrease my
> productivity as a programmer. Since they are development environment
> UI issues, it's been difficult for me to find a good example VI; the
> best I can do is the attached "LV Speed Test.vi". It doesn't test the
> issues that affect me most, but it seems to suffer from the same
> problem.
> This simple VI just shows and hides the menu bar 100 times in a tight
> for loop. When it is the only VI loaded, it executes in about 350 msec
> on my machine. (2.4 GHz P-IV/640 MB RAM/Win2k). However, when I load a
> single project-encompassing VI (let's call it the "giant") that
> references a total of about 900 user and VI-lib subVIs, the test
> routine takes almost a minute and half to run...about 240 times
> slower! I've tried this on my laptop with similar results.
> The problem appears to be related to the *number* of VIs loaded and
> not the memory utilization. For example, if I close the "giant", and
> create a new VI ("memhog") that does nothing but initialize a length
> 20,000,000 array of doubles and stores it in an uninitialized shift
> register, LabView's overall memory usage (as shown in the task
> manager) jumps enormously, but LV Speed Test executes in about 450
> msec...only slightly slower than with a fresh copy of Labview.
> The problem seems to be related to excessive context switching. The
> Windows task manager shows over a thirteen hundred page faults occur
> when "LV Speed Test" is run with the "giant" in the background, versus
> zero or none when run by itself or when "memhog" has used up 160+MB of
> space.
> The problem only seems to affect the frontmost window. (Unfortunately,
> that's where we LV programmers spend all of our time!) If you start
> "LV Speed Test" and then put "giant" in the foreground "LV Speed Test"
> runs much faster. In fact, if you use the VI server to put the "giant"
> VI in the foreground programmatically at the start of "LV Speed Test",
> execution time drops back to 450 msec, and there are no page faults!
> These results show the issue is not related to video drivers or the
> Windows virtual memory system. My suspicion is that there is a faulty
> routine in LV 7.1 that is traversing the entire VI hierarchy every
> time certain events are thrown in the foreground window. It could be
> due to a problem with the Windows event tracking system, but this
> seems less likely.
> I have been programming LV for about 7 years and switched from LV 6.1
> to 7.1 about four months ago. I know NI engineers have put thousands
> of hours developing and testing LV 7.1, but honestly I find myself
> wishing I had never upgraded from using LV 6.1. (To whomever thought
> "hide trailing zeros" should be the default for floating point
> controls...what were you thinking?!)
> I know each new version of LabView causes old-timers like me to grouse
> that things were better back in the days when we etched our block
> diagrams on stone tablets, etc., and honestly I'm not going to go
> back. I am committed to LabView 7.1. I just wish it were not so slow
> on my big projects!
